| Maserati 222 SR problem | |
Vigri
| Titolo: Maserati 222 SR problem Ven 20 Giu 2008 - 10:00 | |
| Hi, I've just bought myself a 91 Maserati 222 SR with a 2.8 liter engine. The car had been not driven for a year. It is in good condition, but the engine has some troubles. When I first test droved it, it started badly and idling was very bad when the engine was cold, but when the engine got warmed up, these problems were gone. Yesterday the car was delivered to me. The problems mentioned earlier were not gone but they were not so serious anymore. So I went for a drive. Got to drive about 3km and then when I lifted foot off gas pedal the engine stalled. It started again when I tried, ran for about 1-2 sec and then again stalled. Started it again, and the engine didn't stall if I pressed gas pedal a little, so I got do drive to nearby gas station with car few more times stalling. But after that when it stalled in the gas station it didn’t start again. There were no weird noises, the car just died and didn't start again. Any ideas what could be the problem considering that the car hasn’t been seriously driven for about a year? I also need to do cam belt change, so all good sites for parts would be helpful, because I live in Estonia and we don't have a local dealer here and it's on of the first Biturbos here. Best regards, Vigri | |
| Titolo: Re: Maserati 222 SR problem Ven 20 Giu 2008 - 21:02 | |
| Hi Vigri! And welcome to Reparto Corse 2! I'm not very practised about mechanical issues, so probably I will not able to solve your problems with your 2.22, but I will try to give you some advices..
The fact that the car has been stopped for a long time time (you say that it hasn't been seriously driven for about a year) isn't a positive thing, because these cars need an utilization quite frequently or, if no used for a long time, like in this case, a regular maintenance, to be preservedserved in a good state.
The sostitution of cam belt is surely a good idea, because this is a mechanic part very delicate. I suggest you the sostitution of the water pump too, cause in this case can cause problems. Unfortunatly I don't know any web site where finding Maserati spare parts, so it'necessary asking to the other members of tis forum.. But in Estonia there are no Official Maserati Distributors to whom ask this informations? | |
maserati vintage
| Titolo: Re: Maserati 222 SR problem Sab 21 Giu 2008 - 12:59 | |
| PER CAPIRE IN SOSTANZA COSA CHIEDE IL NOSTRO AMICO:
Ho appena acquistato uno me 91 Maserati 222 SR con un 2,8 litro motore. L'auto non era stato guidato per un anno. E 'in buona condizione, ma il motore ha alcuni problemi. Quando ho droved prova che si è cominciato male e al minimo è stato molto male quando il motore è stato freddo, ma quando il motore è caldo, questi problemi sono stati esaurite. Ieri la vettura è stata consegnata a me. I problemi accennato in precedenza non erano andati ma non erano più così grave. Così sono andato per un drive. Got alla guida di circa 3 chilometri e poi quando ho alzato piede pedale del gas il motore di una situazione di stallo. Si è cominciato di nuovo quando ho cercato, correva per circa 1-2 secondi e poi di nuovo una situazione di stallo. Iniziato di nuovo, e il motore non ha stallo se ho premuto il pedale del gas un po ', così ho ottenuto fare unità vicino alla stazione di benzina con auto più volte pochi stallo. Ma dopo che quando è bloccato in stazione non ricominciare. Non ci sono stati strani rumori, la vettura appena morto e non ricominciare. Tutte le idee su ciò che potrebbe essere il problema visto che l'auto non è stata seriamente guidato per circa un anno? Ho anche bisogno di fare cam cintura di cambiamento, per cui tutti i siti per le parti sarebbe utile, perché io vivo in Estonia e non abbiamo un rivenditore locale e qui è il primo di Biturbos qui. | |
maserati vintage
| Titolo: Re: Maserati 222 SR problem Sab 21 Giu 2008 - 13:07 | |
| HELLO Virgin, you can start with doing a clarification of the engine: - Replacement candles - replacement petrol filter - Replacement air - replacement oil filter and engine oil - cleaning the tank with petrol extraction of fuel old - adopt a clean injectors to be paid in the tank to transactions concluded - verify trafilaggi of engine oil or coolant in the combustion chamber. | |
| Titolo: Re: Maserati 222 SR problem Sab 21 Giu 2008 - 15:01 | |
maserati vintage
| Titolo: Re: Maserati 222 SR problem Sab 21 Giu 2008 - 17:21 | |
| ottima precisazione davide | |
Vigri
| Titolo: Re: Maserati 222 SR problem Mer 25 Giu 2008 - 8:58 | |
| Thanks for advise.
The work is in progress on the car. The fuel pressure seems to be little low so meybe the problem is there. | |
olograf
| Titolo: Re: Maserati 222 SR problem Mer 25 Giu 2008 - 17:02 | |
| Hi Vigri, congratulations for your new lonely car. Shurely the failure you noticed was related to the fuel feeding, and you confirm a low fuel pressure. Regarding a site where to buy spare parts, the nearest to you that I know is in Germany. Try in eBay to find the shop: Maserati.Parts.International Bye | |
Vigri
| Titolo: Re: Maserati 222 SR problem Dom 29 Giu 2008 - 19:06 | |
| Fuel pressure is about 3 bar, so that shoudn't be the problem. But the spark plugs were black so it indicates that car was running rich mixture before. What could be the cause of it? | |
Vigri
| Titolo: Re: Maserati 222 SR problem Lun 21 Lug 2008 - 11:57 | |
| Hi, I got the car running finally. The problem was in the coolant temperature sensor. I also changes timing belt, engine oil, coolant, brake fluid and had some more little thing done. Now the car runs well. Thanks to all for help you provided. Vigri | |
| Titolo: Re: Maserati 222 SR problem Lun 21 Lug 2008 - 16:34 | |
| So finally you have found the solution of the problem.. I'm verry happy for you Vigri! Ah, and congratulations for your car, is wonderful! For any other things you know that we are here.. Bye! | |
Vigri
| Titolo: Re: Maserati 222 SR problem Mer 23 Lug 2008 - 11:31 | |
| Hi,
I have used the car now daily for about a week, and it runs great. But there are also some problems left.
· The speedometer doesn’t show the speed correctly, when I drive at 100 km/h speedometer shows 70 km/h.
· The fuel level gauge only shows maximum of ¼ of the tank even if the tank is full.
· When the air conditioning is turned on it started to blow in bad stink but when air conditioning is turned off it stops. Does it have somewhere an air filter for air conditioning unit or what might be the problem? | |
Vigri
| Titolo: Re: Maserati 222 SR problem Lun 11 Ago 2008 - 7:51 | |
| Hi,
When I was doing over radio contacts something in passenger side door made a really loud click. After that the central locking doesn't work any more. When I sit in and shut the do something near glove compartment makes some roaring (can't find a better word) noise for a second or so and then it stops. But when one door is locked and other is not and the doors are closed that same sound appears again but is constant and doesn't go away after while.
Did some investigation and found out what is making that noise and it seems like central locking control unit. Module is made by "bitron video", and has P/N 2043018 on the case. It also bears # 549.197 on the case. I also checked all the fuses in the main fuse box and all 14 of them were OK.
After some further investigation found the right fuse, and it’s OK. There are also cigar lighter and door open lights under that same fuse. Also it has 12 V when the ignition is turned on. But when I measured the voltage on cigar lighter contacts then there was only 0,5 volts and it was there weather the ignition was on or off.
It seems like a bad contact somewhere but I have no idea where to search from.
Maybe you have a electrical schema for this model? | |
| Titolo: Re: Maserati 222 SR problem Mar 26 Ago 2008 - 15:56 | |
| Hi Vigri! I'm not happy to see that you still have some problems with your 222SR.. In expectation of the answer of the thechnical experts of the forum, I suggest you, if you want, to control the site named "Enrico's Maserati Page". I hope that you'll finally find a solution to the problems of your Maserati.. http://www.maserati-alfieri.co.uk/alfieri00a.htm | |
Vigri
| Titolo: Re: Maserati 222 SR problem Lun 2 Feb 2009 - 16:22 | |
| Hi,
I had a probelm with my gearbox. It made som sound in second and third gear. So I gave my gearbox to my mechanic friend who is going to do the work on this box and he had a question about replacing the paper seals on the gearbox. He said that usually they prefer to use silicon instead of paper seals, because it is longer lasting then paper seals. But because these seals are rather thick he thought that it might mess up the tolerances in the gearbox. Maybe someone who has done some work on Maserati gearboxes what’s the best way to go.
Vigri | |
Ospite Ospite
| Titolo: Re: Maserati 222 SR problem Dom 15 Mar 2009 - 5:16 | |
| - Vigri ha scritto:
- Hi,
Best regards, Vigri Hi, I just joined this forum today. Hope to make some freinds. To all biturboistas i have a CD of the official maserati service manual for all Biturbos including this one. Anyone in need of it let me know. Its about 500 pages and covers 2.0 l, 2.5 l and 2.8 l engines, electrics, suspension, interiors, exteriors, brakes etc. Sounds like you could use it. Spread the word |
Charlie
| Titolo: Re: Maserati 222 SR problem Dom 15 Mar 2009 - 6:16 | |
| Hi Vincent, welcome to the Forum. I'm sure there is gonna be more than one guy interested in the manuals.Thanks for sharing with us.
Would be nice if you could post some pics of your maserati into the dedicated area called "Galleria".There you can find lots of our pictures.
Keep in touch. | |
| Titolo: Re: Maserati 222 SR problem Dom 15 Mar 2009 - 10:56 | |
| Hello Vincent, welcome between us from me too. About the manual for Biturbo models, if you mean the "Maserati Biturbo Service Manual 2nd edition All-in-one", we already provided to put it into the download area. http://www.granucci.net/DOWNLOAD/Biturbo/maserati_biturbo_service_manual.htm Anyway thanks! Hoping to read something from you again, I wish you a nice day. Davide. | |
Vigri
| Titolo: Re: Maserati 222 SR problem Mar 15 Set 2009 - 7:54 | |
| Hi,
I have a quite interesting problem with my Maserati 222 SR.
I was driving on a track day last weekend and when the car revs got to about 5500 something cut off engine power. It felt like something hit you in the face. I had to take foot completely off the gas pedal and only then when I again pushed the pedal the power came back. The car wither cut off fuel or ignition, but I don’t know witch one and why.
This problem first occurred when I bought the car over a year ago, but it went away after I regulated the idle speed, changed the spark plug cables and all the vacuum hoses. But now the problem with the idle speed problem has came back so when I take my foot off the gas pedal revs start jumping especially with cold engine and adjusting the idle speed doesn’t seem to cure the problem anymore like it did the first time.
Any ideas what could be the problems and how to cure them? | |
| Titolo: Re: Maserati 222 SR problem | |
